Wisper Query
gonyosoma
9
Dear all,
is there any difference in the ride on a Wisper with an 8ah battery rather than a 14ah battery? Is it just range affected or also power if climbing up a hill.
And is the frame geometry on the tourer identical to that on the city/sport?
Much obliged,
chris
Mussels
3,207
Crowborough
The 8ah battery will start to lose power sooner so may be slower over the same distance but unless you are going over 20 miles on a charge you probably won't notice. If you regularly travel 20 miles on a charge then the 8ah may have a shorter life than the less taxed 14ah battery.
I'm pretty sure the 906XC has the same size frame as the 905 range, the 906 Alpino has a bigger frame.
