For Sale Wisper 929 Torque electric hybrid
DennisM
May 22, 2019
67
Bike has done 550 miles since new in 2016. Very good condition with only minor cosmetic scratches (see pictures). This is a torque sensor machine. The motor senses how hard you are pushing and helps appropriately. This is much better that the cadence sensor machines which monitor how fast you are pedalling and then add power. If you are starting off up a steep hill, the motor only helps once you have got going. Torque sensor machines help straight away. Bought two electric bikes so my wife and I can go out together. I love mine, but she never makes time to use it, so this one will go.
Manufacturers spec details:
  • Motor: Wisper High efficiency, 250W hi torque brushless motor
  • Frame: 19in Hand welded, 6061 Alloy T4 and T6 tempered
  • Forks: Suntour XCM/SR 29 adjustable suspension forks with preload and lock out
  • Gears: 27 Speed - Alivio Derailleur and Front mech, 9 speed cassette
  • Brakes: Tektro Hydraulic vented disc brakes 180mm front and 160mm rear
  • Wheels: Alloy double walled 29” x 1.5”
  • Battery: 375Wh (10.4Ah) battery up to 35 miles*
£750 OVNO
Reactions: Wisper Bikes
