Wisper 905se battery not charging
marco12
12
Hi all, interesting problem has cropped up, when putting my wisper 905se on charge, the amber light switches straight to green and the fan cuts out, subsequently, I cannot charge up the battery, I have (with damaging the holder) changed the top battery fuse, and checked the fuse on the charger, apart from that I'm lost,the battery is only about 18 months to 2 years old. Anyone had similar or the same problem occur? I would as always be very grateful for any responses. Thank you
Check the charger output with a voltmeter. Then, check the charge socket with a voltmeter. Those two results will point to the cause of the problem.
marco12
12
Thanks d8veh, I've just pulled the battery apart, checked everything, it turns out the fuse I changed was also a dud, and the one after that! What are the odds? Out of a set of 10 only about three are viable. The thing is up and running now, I'll keep you informed
