I collected the Wisper 705 with 575Wh battery from CH White & Son. I previously bought a Brommie from them and they have given me good advice. I was given a wedge for the brake caliper when I said I'd need to take the front wheel out to get it in the car. I think it was last year's model at last year's price. I'm not aware of any differences from this year's model and it was a saving of £150.
Configuration:
The handlebars are high although there is an adjustable stem to lower them. I've put it on the lowest setting but they are still a good height. The low-step frame is long in terms of the access space and easy to step through. I like the looks of the oversized swooping and shaped main frame tube. It reminds me of some European made recumbents. To my eyes this is so much nicer, more friendly and less aggressive than the blocky down tubes used with integrated batteries.
I've fitted a dual-legged BTWin stand. These make maintenance easier though the OEM side stand might actually be more secure.
The original gearing used a 7 speed Shimano 14-28T freewheel and the chainring was 52T, hence gearing around 48”-96" which strikes me as being rather high. I changed the gearing to an 8-speed Sunrace 13-32T freewheel and a 46T chainring with chainguard to provide a 37”-91" gear range. The 8-speed freewheel is wider than the 7-speed one. I thought the wheel would have a removable spacer on the axle to allow the 8-speed one to fit between the chain stays but apparently not, unless I missed a trick. I find this odd because Wisper used to sell an 8-speed 705. I guess this had wider spaced chainstays than the 7-speed version. Anyway I was able to splay the chain stays by hand to get the hub in. I've removed and reinstalled the wheel a couple of times now so it's ok indoors but I wouldn't want to do it on the road.
I wanted to make it easier to reach the ground from the saddle, so I did two things. I changed the crankset from 170mm to 172.5mm, and changed the 50mm Kenda tyres to 42mm Pasela PT tyres. The first task proved to be painful because the cranks had been overtightened and the thread ripped from the LH one when trying to pull it off the spindle. I had to dremmel the crank off.
The front wheel bearings were too tight so I slackened off the cones after adding grease.
I added a sprung saddle.
Ride
I’m using the bike for an occasional 46-mile commute, which I can usually complete on one charge. I spend a lot of time at 24.9 km/h in 7th gear. Average speed for the journey is about 13 mph. I have it on power level 4 for most of the time, dropping to 3 around junctions. There are some steepish climbs, one is s half mile long with gradient peaking at around 10% which I climb at about 9mph (stats from Strava). I did run out of charge on one occasion after using PAS level 5 quite a lot. So now I leave it on level 4 and spin more. The speed sensor kicks in and out in pulses around 25 kmh which feels a bit strange at first. Maybe that makes good use of the battery, encouraging me to keep up the effort of staying above 25 kmh.
I think the 8-speed freewheel contributes to the good battery range. It means that leg power and motor power can work closely in harmony.
I find that the hydraulic brakes give a good feel when stopping. I also enjoy the comfort of the front suspension. The other thing was that I use the twist grip throttle to help get going on slopes. It is natural to push on the pedal and twist the throttle at the same time.
Final thoughts
I am very happy with the bike. The ergonomics really suit me. It’s been totally reliable, and the twist throttle is brilliant. It’s preferable to a thumb throttle and I wouldn’t want to be without it. I think it’s a deal-breaker for a bike with a cadence sensor.
Now that Wisper have the Wayfarer as a trail bike I think they should refocus the 705 for the road. It should come with 8-speed or 9-speed freewheels and lighter wheels and tyres. Going further, maybe lower the BB a bit and fit a monoshock fork like some of the Gazelle’s have?
Configuration:
Ride
Final thoughts
