Hi all,
I've had a search and can't find anything apart from 103Alex's incredibly complex and clever wiring of lights on his bike build.
I'm hoping to go with something much simpler for my first (36V) build. Detail of possible lights at base of this message
I was thinking of having a switch on the bars but having seen the complexities of Alex's build am now thinking switch in the bag with controller & battery is fine!
Can I take the feed after the S12S controller, so all lights are switched off when controller powered down?
Should I include a fuse? If so how does one do this? car fuses?
Any good sources of switches to use? I would like something along the lines of OFF (no lights), low (rear flashing only) and high (all lights on, Cree can be switched on/off directly by switch on rear of light). 3 separate switches would be fine if a 3 pole is a pain. Water resistant switch would be nice, but not a must.
Thanks again for all the help so far - I'd be stumped without this forum!
Lights:
Lights:
- 3 12V flashing red LEDs on the rear in series:http://www.ebay.co.uk/itm/200983992161
- + 1 or 2 solid red LEDs on rear running off 36Vhttp://www.ebay.co.uk/itm/310757301867?_trksid=p2055119.m1438.l2649&var=610212304833&ssPageName=STRK%3AMEBIDX%3AIT
- + 2 solid white LEDs on front running off 36Vhttp://www.ebay.co.uk/itm/261185677441?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
- + optionally my current dealextreme magicshine clone (Cree) running off a voltage transformer (needs 8.8V)
