Wireless battery charging for e-Bikes
Why? The entire geometry of bikes works against it.. these wireless tech are usually transformers with an air gap between the driving coil and the receiving coil. The bigger the area and the shorter the gap , the better. In a mobile phone, the gap for my Samsung is a couple of Millimetres , an automobile would have the wheel radius as a gap , but the floor area of the car could be used . Bikes have bigger wheels, no floor area, and the weight of the receiving coil is dead weight.... Plugging a cable into a socket, is not an onerous task. Even in the arrangement as shown, the paddle sticking out of the side of the front fork is another obstacle, additional weight, and a wind gatherer... There is a reason why bikes use spokes in wheels. Cycle in blustery conditions with side winds etc...
There might be more sense in including the mains adaptor charger in the bike and using a lightweight power cord, as it is only 1 amp ...
30,608
The Swiss have long had an obsession with induction charging and power transfer, not sure why. The earliest I remember many years ago was a flywheel propelled bus, which at bus stops had induced power driving the flywheel back up to speed to drive the bus to the next stop.
As Danidl has posted, bike shape is very unsuited to induction charging.
Fordulike
3,802
1,538
because connectors are the weak points, liable to be corroded, vandalised etc.
I don't usually disagree with any of your comments, but I think you're over-dramatising an issue that doesn't really exist.
danielrlee
1,394
723
Westbury, Wiltshire
torquetech.co.uk
Another reason wireless charging is a bad idea is that it's horribly inefficient. Even a well designed induction charging solution is an order of magnitude more inefficient than wired charging and that's forgetting many of the issues raised above.
5,786
Yes but when it is your only option it is a life saver - my 2013 Google nexus 7 tablet has a faulty USB charging interface and can only be charged by induction now. So it is a bad idea which has some uses. :)
rower
65
28
39
Berks and Bucks
It sounds good to me, this could help with bikes in which batteries are more firmly secured e.g. inside the frame or even wheels. Clearly the most sensible application would be in shared ebike schemes where a client can just stick the bike inside its cradle instead of faffing around with cables.
30,608
No need for cables and plugs, so why have the terrible induction inefficiency wastage when contact pads on the bike and in the cradle work perfectly ok? It is after all only charging current which pads easily handle.
I can't see it working. Effectively, you'd need an on-board charger and induction coil, which will add weight. induction charging is great for flat things like phones and tablets, but would be a nightmare on an ebike. You'd be better off putting a dynamo in the front wheel and charge it by pedalling.
Reactions: mike killay
MikelBikel
950
336
I didn't know there were so many self-docking, self-charging and in some cases self-emptying robo-vacuums and robo-lawnmowers! Electric bike makers had better wake up? Hehe :rolleyes:
Mikel
16,878
  • Disagree
Gubbins
There has been talk of electrifying roads.. charge while you drive...
So to be of any practically use the current transfer would need to be high . Iwouldnt want to be inbetween the transmitter and receiver.. it might make my hair curl.. If I had any that is..
16,878
TV transmitters are much more powerful than an e-bike charger.
there are also plenty of non-radiative wireless charging designs.
google up resonnant inductive coupling transfers.
16,878
e-bike chargers use a small transformer to transfer the energy from the mains to the battery. When you look closely, what you do here is simply to replace that small transformer by a bigger one. The rest of the design differs little. Also, a little shielding can go a long way, like the mesh on the door of your microwave oven.
Gubbins
So what are you saying? To avoid exposure to a room charger that is transmitting some sort of radiation 24/7 i will need to wear mesh suit?
16,878
you don't wear a mesh suit when you use your microwave oven because the mesh on the door stops 99.999% of the radiation. The body absorbs very little radiation below the microwave frequencies. E-bike chargers run between 10kHz to 100kHz, they don't even have mesh shields.
Nothing to worry about.
Gubbins
Sorry, at cross purposes.. of was discussing wireless charging..
16,878
wireless charging is not different compared to your current e-bike charger.
The basic design is the same, except for the transformer that separates the battery side from the mains.
