Hi
First post - be gentle
I would like to fit a TSDZ2 with 42T chainring to my 2016 Trek Marlin 7 hardtail mtb (29er).
From the drawings I could find, the Tongsheng has a 50.2mm chainline. The chainline of the 40T triple on my Trek is about 56mm (see photo) and there's about 5mm clearance between chainring and chainstay. I think the TSDZ2 with bigger 42T chainring would catch on the chainstay. The reduction gear might also clash?? So I'm looking for advice on how to get about 5mm extra clearance on the drive side.
My bottom bracket is 73mm. If I get a 5mm spacer to fit on the drive side of the bottom bracket, will there be enough thread to fit the lock nut on the non-drive side? I could maybe shave 1-2mm off the bottom bracket with a grinder, but doubt I could find 5mm.
Alternatively, are there any spacers that fit between the Tongsheng drive and the chain ring / spider? I've googled lots, searched ES etc, but all I get are Bafang spacers. I guess I could ghetto something up with washers? What do people advise?
I've spent hours trawling www. I did find a post on ES when someone had fitted a BBSHD to this exact bike; they didnt use spacers but used a Luna chainring adapter.
Jim
Jim
