Which torque arm for rear 350w yosepower ebay if possible
it is i footpump
102
23
76
Hi all i have 350w yosepower rear hub moter on my mtb , but will be fitting 17amp controller, and using a 48v battery .
as there will be more strain on the moter etc i think a torque arm will be needed please suggest a torque arm and how to fit. Thank you
8,841
3,994
Can you show what you ordered? i recommend one like this, which is hardened steel. Many on Ebay are stamped out of non-hardened steel. They're easy to fit. Put it on the left side and fix the tie-bar to the lower caliper adapter screw. Use washers to fill the gap when it sits above the surface. You'll need a longer bolt for the caliper adapter.
