My A2b Kuo is very under geared and I intend to fit a larger chainwheel and longer cranks. The existing unit has the sensor stator and pickup as one sealed unit integral with the chainwheel. the stator part is located by two pins mounted on the BB. This arrangement appears to be a torque sensing device as the pedals turn a few degrees against strong springs before the rotating disk moves.
[/URL]
The control box is this one, no maker's name,
[/URL]
Three wires go from the unit to the controller,red ,blue, green. My question is can any one suggest a replacement sensor disk and pickup of the more common type to substitute here so that I can fit a standard chainwheel. Thanks all.
