Which PAS Sensor Type for Sram 1x11
8,517
The specs of the motor says that the motor rpm is 470 that is either a print error or if right a very high motor rpm, if you have any hills it will bog down and stall unless one can keep the motor spinning very fast.
For PAS the pic's are 100% as we can't see the actual BB set up behind the cranks, the pics are too straight on and not angles enough to tell but one assumes it has sram gxp BB, if so then the bzc10 or the third option is required.
