Which controller kit do i buy?
mxlann
Feb 18, 2025
So basically i have a ebike with a ananda d16 display, a ananda b5 controller, a m150sd motor and a 48v battery. I wanna buy a new controller and display so i can get some more power and speed. Which controller kit would be compatible with these parts?
3,738
Does your 36v battery still work, and do you still want to use it? do you want cheap and chearful or a nice control system? How much extra power do you want?
mxlann
Feb 18, 2025
What do you mean 36v? its 48v, but i would want something thats under 100 euros. The motor i have right now puts out something like 900 watts. If possible i would want 1000 watts or more.
3,738
Puts out 900w.
Are you sure about that? 900w output is 25A at 48v. Ananda says the B5 controller is 20A max, and that's probably at 36v. Is there a label on it indicating the max current?
Once you go over 20A at 48v, pedalling is a waste of time, so you don't need a special controller. For 1000w output, that is going to severely stress your motor, you need a controller with a max current of 26A to 28A - a 12 MOSFET one. All controllers work the same. All you need to do is wire them up right. Different ones have different optional features, so choose one that has what you want. Always buy the matching LCD with it if it has one.
Another important consideration is your battery. Can it supply more than 25A continuous, which is what you'd need. Most can't!
