which charger?
paul2978
7
surrey
Hi,
So thanks to the help from the people here: see post
http://www.pedelecs.co.uk/forum/threads/custom-battery-smaller-for-less-miles.25532/#post-330238
I now have a new working battery.
However it didnt come with a charger. I am currently using an old power devil charge as it does appear to charge the battery, but is this the right one? Can anyone recommend a good charger to use?
I cant use the older one for the lead batteries as the connection is now different?
Thanks Paul
Fordulike
3,802
1,538
As long as the output voltage is 29.4v, then that should be fine. If it is exactly 29v, as stated on the Power Devil, then it might slightly undercharge the pack.
Also, 400mA is a pretty paltry output current, and the battery will take a very long time to fully charge. 25 hours for a 10Ah battery!
This one might be more suitable, but check with the seller that the output plug is the same first. Looks the same style though.
Li-ion Battery for electric bicycle e-bike 24V 1.5Ah charger Lithium
