Hi, I'm looking for a long extension cable for the motor or 2 separate cables (1 male / 1 female) ... I can find male motor cables but not the female ends from the controller.
Spec :
"Old style" connections (not waterproof connectors)
Male from motor (2 required if possible) 1 length 70cm, other can be any length.
Male/Female extension to run from the controller to the headstock, length 1.4m would be ideal.
If I can't find an extension I can splice a new female end onto the existing harness if I can get a female end...
Any suggestions please or does anyone have any scrap cables for sale ?
I can see some on Amazon.com at good prices but delivery is weeks
Can't see any extension cables on Amazon.UK or Ebay.UK, and ones that look close are often £15 each which gets expensive as I want 3 ends.
Background.
This is for my Dutch town bike https://www.pedelecs.co.uk/forum/threads/kemp-starley-dutch-town-bike-out-of-hibernation.37181/
I also have a problem with the motor internals but think I have that fixed now https://www.pedelecs.co.uk/forum/threads/fixing-older-wheel-controller-are-all-hub-motor-transistors-similar.48005/#post-729202
The motor cable on the original front motor was damaged and needs to be replaced.
I'm now using a spare motor - it was working but the motor cable is about 2m long (photo in the build thread) and is routed internally through the frame making maintenance a nightmare.
I'm planning to cut the existing over-long motor cable and put a connector by the headstock for maintenance, and replace the damaged cable on the original motor so I have a spare motor.
Many thanks
Spec :
Background.
Many thanks
