What a miserable week!
Found out I had a puncture in the rear wheel of my Twist whilst at work on Weds, even though I had Marathon+ on. I had noticed that the pressure kept dropping over the last few weeks from 60 down to 50. It was raining, so I didnt bother looking for it, just swapped the inner tube and checked the tyre, found a shard of metal stuck through the tyre (it was about 13mm long 1-2mm thick, no nail head, just a shard). Plucked it out and thought job well done. Had a bit of trouble with the Specialized tube Presta valve, but eventually figured out the valve needs a bit of jiggling when first used (dirty oily hands, really hate that).
Then my Cyclaire pump broke half way to pumping it up, great. Luckily a colleague had a basic pump that I could use.
All in all it took me 45 mins to do, really slow.
Thursday came and went, no problems...
Friday morning, raining again and the tyre was down again.
So at 6:45 am you see me stood next to a bus stop full of people, watching me whilst I frantically try to reinflate the trye (to see if its a fast puncture, or that dodgy valve) with a 8" emergency pump (bought from Tescos for £6.94 that unbelievably comes with a pressure gauge). If anyone here has a 8" pump, they will know that inflating anything to any sort of reasonable pressure is a test of fitness, cardiac function, and tenacity. 10 mins later I was on my way to work, 10.5 miles away. It got me there (checking every couple of miles.
Friday night after work, it was raining much heavier. So I went about changing the tube again. Again checked the tyre, and found nothing. Had real trouble getting it all back together with the wheel and roller brake and the hub gears, couldnt see why (dirty oily hands again, grrrr). 1 mile home I found out why when the Reelight rear light 'fell off' in the middle of heavy traffic. This is a problem as the bracket is on the spindle, meaning that everything was now loose. Pulled over to the side safely enough, then played chicken with the traffic to find my Reelight which was remarkable undamaged, then set to work putting everything back together again in the rain.
15 minutes later, and now having got dirt and oil all over my hands, gloves, hiviz jacket and hand grips, I set off home, wet miserable and downcast, hoping to make it without another set-back. Then noticed that there was a very thin shard of metal, about 10mm long sunk into my finger, so I did find something in the tyre, I just hadnt realised, oh joy!
A bottle of wine later, I began to feel more positive, but one of those weeks you need to write off. So the question is this, does anyone have any tips for avoiding dirty oily hands and getting dirt and oil all over yourself when doing this type of thing at the roadside, it would be much appreciated?
John
John
