Wheel size 26 Inch o.l.d
Wayners
390
86
55
Gloucester
Need a new rear wheel I decided after the new axel I bought never fitted correctly on my 26inch wheel MTB.
6 speed freewheel with 135 o l d (135mm distance across axel)
Most adverts don't mention o.l.d size so I guess you assume it's 135mm?
Is it worth getting a double rim wheel? Any recommendations? Not much of an idea what I'm buying tbh
Cadence
261
200
Most 26" MTB rear wheels are 135mm OLD. Just make sure that the wheel is screw-on freewheel and not freehub (cassette). Some retailers seem to have a problem with listing them correctly!
Most front hub-motor kits seem to have black rims and silver spokes, so if you are trying to match a rear wheel to one this is decent enough:-
Raleigh 26" Rear Wheel, Mach1, Quick Release Axle | Halfords UK
Or if you just want a cheap wheel : -
Raleigh Tru-Build 26" Rear Wheel, Screw On, Nutted Axle | Halfords UK
Only single wall, nutted axle and probably galvanised steel spokes.
Available at other retailers as well as Halfords.
Reactions: Wayners
