Hi folks,
My Kalkhoff Pro-Connect is fitted with magura HS33 hydraulic rim brakes. All functioning well, but I need to take off the wheels to switch the tyres to studded winter tyres.
With my old bikes and regular mechanical brakes I am used to unclipping the wire to open out the blocks and remove the wheel without having to deflate. How to do this with the HS33 mechanism? I cannot find any documentation outlining simple basic maintenance with these brakes.
There is a small metal lever which says "close" and "open" by the brake block housing. That seems to release the block on that side. I am afraid to do too much without guidance otherwise I am liable to end up with a pile of screws, lugs, springs, things, pivots, rivots and probably brake fluid all over the floor...
Thanks for any help!
