Wheel change on 2014 bike
Seanoge
182
14
79
Gulval, Penzance
It was pointed out to me at Halfords that my 2014 Freego Regency needed a new back Wheel Rim. If I change the whole wheel out with a new Motor.......would this change the "Grandfather Rights" on the bike?
3,678
Changing the motor shouldn't change anything. Your bike is still a 2014 Freego Regency that had the throttle on it in 2014. What about when you change the tyre or the brake pads? Nobody cares about that, so I don't see why the motor would make a difference.
Do you have an old forum post with a picture of your bike or anything like that, or is there a plate on the bike showing its date, or maybe the serial number? Anything like that would help as evidence.
Although you're supposed to be innocent until proved guilty, in this case it's more likely to be the other way round. If you haven't got anything, it might be an idea to find an old review of your bike and download it onto your phone or do a printout, so that if ever you were asked, you'd have the evidence.
thelarkbox
1,460
454
oxon
Rebuilding a wheel with a new rim is no longer the dark art thanks to lots n lots of 10,imute+ youtube how-to vids..
Yes you will screw up and have to restart at least once , missing a hole or not ;) but the tools needed are minimal and empty front forks make an adequate balancing jig using snipped cable ties as guides (watch the vids and the penny will drop)
3,678
It's a rear motor, so won't fit in forks. Personally, I never use any sort of jig. I just do it on my lap until all the spokes are in, then I put it in the actual frame to finish it off, using a couple of cable ties to show where it needs truing. That way, you get the rim exactly in the middle of the frame. Rear motors usually need a bit of offset built in to get the rim in the centre, so doing it in a jig isn't as good unless you know the offset before you start.
Reactions: flash and flecc
30,768
I can't see you've posted about it early enough, only posts from 2020 and 2021 referring to its 5 or 6 years age respectively.
However, here are three links from 2011 to 2015 referring to the Freego Regency in the days long ago when it was a current model, so they should be proof enough of your Wife's elderly bike's vintage:
Seanoge
182
14
79
Gulval, Penzance
I presume that 14 refers to year, I have the same bike except 18. I'm worried now as I have the same marks on my wheel rim. Measuring with a caliper they are both 25mm at the widest point.
Halfords said the 14 bike needed a new wheel rim, but I'm sure he didn't examine it much....as he refused to service it. Any advice on how I can actually find out?
The 2nd. image is the 14 bike, the 3rd. the 18.both look the same to me.....
AndyBike
1,583
663
Bit of a grey area really.
Was the work carried out by a qualified bike mechanic ?(home trained isnt the same as qualified professional)
If not then that might invalidate the guarantee .
Even changing wheels or anything, needs to be done by pro mechanic.
There was a recent case with Giant. Their carbon Ebike frames were in some cases suffering from cracking, and the owners found that Giant wouldnt honour the guarantee. Reason given was the owner had fitted oem/new parts.
If the manufacturer was to play hard ball they could say naff off as an entire new motor isnt part of original equipment
Unlikely of course in most cases, but the law would still stand and you would be unable to fight against it.
3,678
Just point to the serial number and say "Week 04 2014". It would still help to have some backup evidence to show that the throttle was fitted from new, like a review from 2014, forum posts. pictures or anything like that. As time goes on, you won't be able to find those things on the internet, so get them now.
3,678
The bike is more than ten years old and Freego have disappeared off the face of the Earth, so I don't think he's too worried about the guarantee.
Reactions: AndyBike
30,768
Below is a link to page 7, Operational Instructions, of the Freego Regency Owners Manual. This refers to the throttle several times and confirms it had a twist throttle fitted as standard.
Print that out as the proof you need.
Seanoge
182
14
79
Gulval, Penzance
Below is a link to page 7, Operational Instructions, of the Freego Regency Owners Manual. This refers to the throttle several times and conforms it had a twist throttle fitted as standard.
Great, thanks for that.
8,718
Buy a new rim and lace the old hub back in.
Seanoge
182
14
79
Gulval, Penzance
You think the Rims need replacing then?. I'm too old to do it myself so will be getting a Mechanic to do it......that's why I thought a new wheel and motor may be easier & cheaper.
8,718
Rims have a wear indicator on them , this is a complete shallow grooved line around the rim. Once that indiactor grooved line can no longer be seen/worn away in place's then it is time to think about replacement .
From the pics they don't look nothing to worry about.
Seanoge
182
14
79
Gulval, Penzance
One last question, it will have to have a service somewhere..........was looking at Yose conversion Kits.......reasonably priced......would it be worthwhile installing a new rear wheel and motor......have motors improved much in the last 10 years that it would be worth it?
8,718
Tbh if one is happy with the hub and it has proven reliable then there is little reason to want to change it , for the sake of having something shiny and new.
Your current hub is legal and probably marked 250w or the bike label will denote 250w , with the Yose one will have to be careful and buy a 250w kit.
3,678
Motors aren't much better than each other. They're all very reliable. Size matters. The bigger they are, the more power they can handle. There ar exceptions to that: Most AKM motors have a higher reduction ratio that allows them to run faster inside, so that gives a bit more power and torque at low speed. There are also some small Bafangs with high reduction ratio.
I doubt that you'll see much difference from changing the motor. It's the controller that makes more difference than anything, and the Yose one isn't that good.
Whoever is doing the servicing at that Sustrans event, if you ask them nicely, they might build your new wheel for you if you ask them nicely, or at least they'll know someone who can do it. Give them some sob story about why you can't afford to get it done at a shop.
Seanoge
182
14
79
Gulval, Penzance
Well, that's that. Was planning on visiting SusTrans tomorrow with the '14 bike. The venue is about 2 miles from us ...but at 66m compared to us at 10m........it is a long slow climb......My wife's battery is a Freego....a bit old so thought I would carry my Yose battery that I use for my '18 bike in reserve. Tried it and it doesn't fit.......I think I had the same problem when I bought the Freego 2018 bike, and a local ebike specialist sorted it for me. He is no longer in Buisness. So no Sustrans tomorrow.....shame. Thanks for all the suggestions........
The 1st. Pic. is the '14 bike and the Freego battery is nearest......
