What the diffrence between 15Ah and 18Ah Battery
glesgaguy
10
Hi Guys excuse my ignorance here, but what is the big deal about the 18 Ah batteries for Kalkhoff machines, what difference in real terms will 3 Ah make?
Thanks in Advance
Andy
dmcgoldrick
446
-1
Thanks in Advance
Andy
about 10 extra assist miles over average terrain per charge........
regards
30,836
The Ah (Ampere hours) is the capacity of the battery, in crude terms representing the range the e-bike is capable of. So in this given case the extra 3 Ah will extend the range by one fifth over the 15 Ah one.
If the two batteries are different makes and constructions or two different e-bikes are being compared, there may be little difference in practice with that capacity difference.
N.B. Crossed with dmcgoldrick's post
Not too sure about whether the effect is the same on a Kalkhoff, but for most other bikes, as well as longer range, you get higher speed and more climbing power because you get less voltage sag from a bigger battery. It can make 10% to 15% difference.
