What soldering iron ?
AndyBike
1,499
636
Not for me, but to answer a question on another forum.
My soldering iron cost 99p :D so im not the best person to give a recommendation
thelarkbox
1,388
429
oxon
Ive got a 5v 8w usb iron too ;) works ok on small things with minimal heatsinking capacity.
but a ts100/80 or clone is a big boy version of the same format, and can dump 60w+ from a suitable dc psu (usbc). google suggests they are very cheap compared to the £60 i paid for a 3 tip bundle originally.. (£15???)
but if doing really big things that soak away lots of heat a mains powered desk station might be best?
3,509
Horses for courses. You want a low power one for doing most stuff on PCBs, and a high powered one for doing battery and motor connections.
AndyBike
1,499
636
This is the question posed -
" I've used a Weller TCP-1 with a PU-1D since forever now but it's a bit brutal for modern SMD stuff, so I'd like to also have an iron that is suitable for much smaller stuff.
Does anyone here have a recommendation for something temp controlled for tiny SMD components or am I better just trying to find lower temp bits for my TCP iron? I'm just finding that unless I work super fast my current number 7 bit will just lift the solder pads on the board. "
6,635
3,509
Where is the question? I don't see it and I'm not an FMR.
