Help! What size step through e-bike for 165cm?
daynoir
Aug 23, 2020
Hi all,
I've been lurking, trying to find clarity on types and brands and everything e-bike related. Thank you for all of your discussions - they've helped!
However, I'm a bit stuck when it comes to e-bike sizes - I'm 165cm tall and want a step-through, (with a £1200ish budget). Which bikes are going to be okay for me?
I think I need to look for a "small" frame? But I can't ever find the info on manufacturer websites - for example which of the Wisper 705 would be most appropriate.. the 24" or 26"? Wheel size, frame size, general size, inches, centimetres, argh!..
can someone help.. what number (s) should I be looking at and what should they be?
Thanks in advance.
16,850
Woosh Santana CD. Currently in stock.
Very smooth, comfortable and capable bike.
Step through Dutch style frame, crank driven, 9--speed Shimano Deore, gear shift sensor, 5-level pedal assist and throttle, hydraulic disc brakes, Suntour NEX suspenson fork, fully equipped with lights, bell, kick stand and mudguards.
Santana-CD with 15AH battery (50 miles range): Only £1,099
Santana-CD with 17AH battery (60 miles range): Only £1,169
Free delivery.
https://wooshbikes.co.uk/?santana-cd
daynoir
Aug 23, 2020
Thanks for the speedy response - I haven't seen chain drive before. I'll have a nosey. Have briefly looked at the Santana3 (it's been mentioned a lot on the forum) - would it be too big?
Edit: does chain drive = crank / mid-drive motor?
16,850
same frame.
If you are less than 1.75m tall, we fit unsprung seat post.
yes.
The Santana CD is a very nice bike, very capable and it has a throttle.
That's as rare as hen's teeth among mid drive bikes.
I like it very much.
With most mid drive bikes, you have to pedal much harder when going uphill, especially when it's steep.
With the Santana CD, you can use the throttle to climb steep hills.
Reactions: daynoir
Wisper Bikes
6,282
2,252
69
Sevenoaks Kent
Hi all,
Thanks in advance.
Hi Daynoir,
Woosh do make great bikes too.
If you would still like to consider a Wisper. I would recommend either the 705 24" or 26" if you a are confident rider go for the larger size.
The most important thing is to test ride a bike first, where are you based? I could recommend a good dealer for you to go and try.
All the best, David
Reactions: daynoir
daynoir
Aug 23, 2020
Thanks David. Trying would be a good idea though I'm not sure many places here are allowing that yet - I'm in Cardiff, Wales.
