Now that the weather is nice, I am starting to test ride e-bikes with the intention of purchasing soon. Today I test rode the new Villiger Leventina, which is the same bike as the Trek T500E.
Villiger: LEVENTINA TOUR E
I was very impressed with the build quality of the bike, and the BionX motor had a good power output.
I found two main problems with the bike though: First at the highest power (level 4), there is a noticeable vibration from the motor. Can I assume this is true of all BionX powered models?
More importantly though, there was a very disturbing effect when riding around 25 km/hr, which in my experience with e-bikes is the speed I usually ride.
With the Villiger, as soon as you go over 25, there is an abrupt power cut and it feels like you are being pulled backwards. As soon as you drop to 23 or 24, the motor gives you a strong push forward. The way I ride, this tend to happen every 100 metres or so, and the push-pull sensation is very unpleasant. Perhaps this is a problem of a first generation bike, and the controller algorithm for gradually diminishing the assist has not quite been worked out yet.
However, the dealer said that the Koga Tesla had exactly the same problem.
Is this a general problem with hub motor bikes?
