What does this bit do???
8,843
That's a torque arm it helps to prevent the drop outs from snapping by resisting the hubs axle from spinning out under high torque. Basically a simple but effective safety feature that prevents you from a face plant.
PH001
118
53
52
Harrogate, N. Yorks
OK, I now understand torque arms! But looking at the stealth setup...is that actually going to be effective? The pic is the view with the bike upside down (on it's handlebars). Surely, the torque reaction will simply try to pull the torque arm horizontally down the frame (sliding the jubilee clip)?? I don't understand how it can be effective mounted like that?
C
Cyclezee
Hi PH001
For a powerful rear motor like yours the Cyclezee V3 multi angle torque arm is a better solution.
They are available with 12 or 14mm inserts.
  • Useful
Reactions: LeighPing and RobF
RobF
4,732
2,312
The Cyclezee torque arm looks a much better job for a powerful motor, not least because of the double anchor to the chain stay.
