December 11, 20169 yr hello, how do I open this light? water are inside and it's not bright anymore...: thank you
December 12, 20169 yr I took mine apart, but it was a long time ago. IIRC, both the front and back unscrew. Get some molegrips on the rings and see if you can unscrew them.
December 12, 20169 yr Author I took mine apart, but it was a long time ago. IIRC, both the front and back unscrew. Get some molegrips on the rings and see if you can unscrew them. Will do. These were ur favourite light long time ago. It does power directly from the battery. Why are they not your favourites anymore?
December 12, 20169 yr They were one of the first lights that could run directly from the battery and give enough light for most circumstances. I still like that one, but my favourite is now this one, though you have the inconvenience of having to keep taking it off every time you park your bike. http://www.ebay.co.uk/itm/3000LM-CREE-XM-L2-LED-Headlight-Front-Bike-Bicycle-HeadLamp-Head-Light-18650-SET-/151628782015?var=&hash=item234dc799bf:m:m3z0uVQHEetlCJ_RNthhqcg I rarely use my bike in the dark now, so that's not a problem for me. If I were in your situation, I'd still be using that same light that you have.
December 12, 20169 yr If you can't get it apart, you could try putting it in an airing cupboard to dry out. If the water got it, it can come out. Putting it in some uncooked rice (in the airing cupboard) might help draw the moisture out. Gaz
December 12, 20169 yr They were one of the first lights that could run directly from the battery and give enough light for most circumstances. I still like that one, but my favourite is now this one, though you have the inconvenience of having to keep taking it off every time you park your bike. http://www.ebay.co.uk/itm/3000LM-CREE-XM-L2-LED-Headlight-Front-Bike-Bicycle-HeadLamp-Head-Light-18650-SET-/151628782015?var=&hash=item234dc799bf:m:m3z0uVQHEetlCJ_RNthhqcg I rarely use my bike in the dark now, so that's not a problem for me. If I were in your situation, I'd still be using that same light that you have. If you use tie wraps instead of robber bands you can have a Permiant mount.
December 12, 20169 yr The light looks like it has been used in a fish tank It really needs opening up and the lens and reflector cleaning and any fish removing You must be a hardcore rider
