M mxer Pedelecer Nov 28, 2010 92 10 May 22, 2017 #1 Can anyone help me with one of these?. 2x6s paralleled into one jst lead I can't find them anywhere here in the UK? Many thanks
anotherkiwi Esteemed Pedelecer Jan 26, 2015 7,845 5,786 The European Union May 22, 2017 #2 HobbyKing. https://hobbyking.com/en_us/jst-xh-parallel-balance-lead-6s-250mm-2xjst-xh-1.html?___store=en_us
Nealh Esteemed Pedelecer Aug 7, 2014 20,917 8,530 61 West Sx RH May 22, 2017 #4 Fairly easy to solder your own up if you are able to solder a bit of heayt shrink on each joint and away you go. Just requires a bit of patience. Reactions: mxer
anotherkiwi Esteemed Pedelecer Jan 26, 2015 7,845 5,786 The European Union May 22, 2017 #5 I know... Haven't had any for months and months. If you are handy at soldering make your own is my advice. Damnation Nealh beat me to it... Reactions: mxer
D Deleted member 4366 Guest May 22, 2017 #6 Use a balance board to connect your batteries. take the back off and run some reinforcement down the two power tracks. That saves all the messy wiring, and you can plug in as many parallel batteries as you want. http://www.ebay.co.uk/itm/LiPo-Charging-Adaptor-Board-2-6S-Charge-Balance-Board-for-imax-B6-B6AC-/182580738756?hash=item2a82a8fac4:g:WiYAAOSwcB5ZHVrx http://www.ebay.co.uk/itm/NEW-LiPo-Charging-Adaptor-Board-XT60-Charge-Balance-Connect-Lipo-for-imax-B6-/222012043367?hash=item33b0f2f067:g:~qQAAOSweW5VYFqR Reactions: mxer
M mxer Pedelecer Nov 28, 2010 92 10 May 23, 2017 #7 Thanks all, I've managed to make on, cheers.. Reactions: awol
