I was starting to think the number had something to do with the casing size so correct me if i am wrong
a Q100H is just a 36v350w - is there any more info on what the Q's stand for as I have never heard a front hub motor being referred to as a Qxxx before.
I took a circumference measurement of my 250W and my broken 350w when I got my 250w a while back and the 350w was slightly bigger, would this effect what you need if for?
Do you require the wheel and spokes, there are in amazingly good order if not you would have to bear with, as my dexterity is so good in the cold not to mention I would have to figure out how to dismantle it first, I suppose this would be cheaper for posting!
One other point for transparency the axle threads on one side are worn they still work with original flange nuts but do NOT seem to take any other nut of the same spec, either I have cross-threaded it at some point and/or its really cheap nasty metal, I do still have the original nuts!
View attachment 22646 View attachment 22647 View attachment 22648 View attachment 22649
