F fireboy Finding my (electric) wheels Aug 2, 2016 11 0 Liverpool Apr 12, 2017 #1 Hi, looking for a working 36v controller made for Cytronex. 36V, 14.5a.
D Deleted member 4366 Guest Apr 12, 2017 #2 You can use a universal controller, like this one, which will be a lot better with 5 levels of assist: https://www.aliexpress.com/item/24v36v48v250w350w-controller-and-display-set-electric-bike-scooter-moped-LCD-control-panel-controller-with-ebs-brake/32793377844.html?spm=2114.01010208.3.27.Vdl5vR&ws_ab_test=searchweb0_0,searchweb201602_4_10152_10065_10151_10068_10130_10136_10137_10060_10138_10062_10156_10153_10141_10056_10055_10054_10059_10099_10103_10102_10096_10148_10147_10052_10053_10142_10107_10050_10143_10051_10084_10083_10080_10082_10081_10110_10111_10112_10113_130_10114_10037_10032_10078_10079_10077_10073_10070_10123_10124,searchweb201603_9,afswitch_1,ppcSwitch_4&btsid=4f8119e1-add9-48fc-b779-d3f35d4cfbbb&algo_expid=08a0c739-f901-4ccc-98ff-29a32d7266e6-3&algo_pvid=08a0c739-f901-4ccc-98ff-29a32d7266e6 You'll probably have to change a couple of connectors or cut them off and join the wires directly.
Woosh Trade Member May 19, 2012 20,348 16,862 Southend on Sea wooshbikes.co.uk Apr 12, 2017 #3 I have a few models of Lishui controllers in stock, may even have an LSW1024-1. Can you post a picture of the controller's connectors?
F fireboy Finding my (electric) wheels Aug 2, 2016 11 0 Liverpool Apr 13, 2017 #4 Controller still attached to bike wiring inside conduit, would take bike to shop to get replacement controller fitted.
D Deleted member 4366 Guest Apr 13, 2017 #5 In that case, you need an OEM replacement otherwise it's going to be expensive. It normally takes me about three hours to adapt, test and setup a non OEM controller.
