virgin v6 box and super hub 3
6,722
anyone got one of these ? and whats the wifi range like on the v6 with 2.4 or 5ghz
Blew it
1,472
97
Swindon, Wiltshire
Yes, I have this system in use. If you need to access the V6 box contents beyond the normal wifi range, then connect to the superhub 3 via the internet. The superhub 3 connects to the V6 box via "powerline" units. (devices communicating through the house AC mains cables). Therefore, any content stored on the V6 box can be viewed hundreds of miles away over the internet. Is that far enough?:eek:
6,722
i want it to use the wifi for the box with my unifi 2.4ghz disc but not sure what data rate it is going to use with all the other devices as well with 350meg bb.
spec says it is 3x mimo wifi for the v6
the disc i have is 2.4 only tho and rated for 300mbps x1 mimo and got 10 devices running on it already.
if it craps out ill try this as cant see there router will be any good tbh.
https://www.4gon.co.uk/ubiquiti-unifi-ac-pro-indoor-outdoor-access-point-p-6638.html
6,722
try get that with sky ;)
