Vintage commuter, 1st ride after conversion today!
Spinnanz
56
17
Up and running today, although currently its all just zip tied together, mostly to make sure it all works! Speed controller is running sensor-less at the moment so acceleration is a bit nosier than it will be when finished. GPS speedo attached to the bars for speed check, that's not staying there.
Did a quick 8km, can maintain 20-22kph without me pedaling at all. If I pedal, its only slightly faster but the current the motor is using drops, therefore (I guess) increasing range.
With the current sprocket ratios of 16/47, I'm pedaling about as fast as id ever want when its at max speed, and it's not geared so high that I cant use it slowly around the park with the kids, so a happy medium. The new wheels are WAY smoother than I expected, Id happily travel faster if the hub and gearing allowed. When up to speed its also quieter than I expected.
