How about a few pictures of the battery and especially the connector and connector polarity?My other half purchased a viking ebike from the shopping channel about two years ago and I believe the battery is goosed
Its a 24 volt bottle battery and I cant find one anywhere for sale
Can anyone advise?
Well done,I am sure that they will help someone with more knowledge here, to help you. All appears to be fairly standard.Thank you pictures here Battery
I dont know if its the cells or the onboard electronics :-(Well done,I am sure that they will help someone with more knowledge here, to help you. All appears to be fairly standard.
Have you considered having the battery "re-celled"? It is possible to do that with some battery cases..
Regards
Andy
Thank you...Well done,I am sure that they will help someone with more knowledge here, to help you. All appears to be fairly standard.
Regards
Andy
that was meant for Steve apologiesThank you...
When I first pluged it in this week after a break of 18 months the charger light was red and the battery warmed up a bit then the charger went greenThe battery displayLEDS indicate no chargeConnecting to the bike doesnt do anythingThe voltage at the battery terminals is a negligible 0.1v.The charger output voltage is around 29v without a loadI would appreciate it if you could do anything with it, let me know what to do next.
That looks the same bike as my wife'sHi Guys,
LIfting the topic, since I have the same issue. Do you think this replacement would do the job for me: https://www.ecarsyou.com/index.php?main_page=product_info&products_id=695736
Thanks!
Beware of the websites offering a replacement they seem to be fraudulent. It can be re-celled but for silly money. I'm looking to find a suitable replacement which may involve adding a carrier to hold a different style of battery. Compared to 6 months ago there seems to be some possible contenders available now from £150 upwards. Some have fitting kits and include a charger unit. Hope you are able to sort yours.My other half purchased a viking ebike from the shopping channel about two years ago and I believe the battery is goosed
Can anyone advise?
The controller is in the base of the receiver. in theory, you can use any battery you want because it's a simple two wire connection, but you need to think about what you can do with the controller. If you don't mind the untidy look, you could keep the receiver and mount a different battery anywhere you want and join it to the receiver prongs with two large spade connectors. Whatever you do, it'll take some creative DIY to reach a solution.Beware of the websites offering a replacement they seem to be fraudulent. It can be re-celled but for silly money. I'm looking to find a suitable replacement which may involve adding a carrier to hold a different style of battery. Compared to 6 months ago there seems to be some possible contenders available now from £150 upwards. Some have fitting kits and include a charger unit. Hope you are able to sort yours.
