Vickyglip new curious member
Vickyglip
Hi to all
New member ,new to cycling with a dodgy knee
Just bought a 906xc tourer which am informed is a limited edition with a test and proving history for whispers early days
Would love to hear about people's memories of any events linked to this model and history
Anyone advise of starting point for the continental fighter 2 tyres air pressure as I,m working on the squeeze principle at present and I,m sure there must be a standard for a 90kg rider
Look forward to hearing from you all and exchanging a few views etc
RobF
4,732
2,312
There should be a pressure range marked on the side of the tyre.
The higher end of that range will give best puncture resistance, but a firmer ride, than the lower end.
Vickyglip
Pressure band
Thanks Rob
I,ll do just that as described by yourself as the bike has air adjustable forks where I tend to feel most of the road bumps from , should be able to dial the bumps out
It really does feel a proper engineered bike that they thought about
Regards
Martin@e-bikeshop
Thanks Rob
Regards
Vicky, if your forks are air sprung, don't by any means, attach a normal bike pump to the valve. It will blast pressure back at you, probably resulting in a face full of fork oil, and no compression left in the chamber..
Use the bike pump on the inner tubes, if you do adjust the shock, buy a proper shock pump, the forks can take a great deal of pressure, and must be made in small increments.. Normally a sticker on the side of the bike that converts your weight into psi. You can then set your air forks to this PSI, refer to the owners manual if the chart is not stuck to the forks.
Alternatively if you get stuck go to a good local bike shop and ask them to help.
Just wanted to give you a heads up as I hear people connecting bike pumps to air forks time and time again :)
Regards
Martin
RobF
4,732
2,312
Looks like Continental say between about 50 and 70psi, which is what I would expect:
Continental Cycle Tyres UK
Edit: Good advice from Martin (above) about the fork.
Vickyglip
Thanks for invaluable info as this sounds dangerous
In your debt pedelec s forum
Regards
Vickyglip
Close 50 to 65 psi but good advice. No idea until contacting you well advised people
Regards
Vickyglip
Just to pick your brains the front led light has four terminals of which two are used leaving two exposed yet the light is daylight sensitive what could the other terminals be fore
Tempted to try the other terminals with existing wiring
Any advice or info please
Regards
