All following are 36V.
Motors;
Tongxin 36v, 260RPM 36H narrow (80mm wide), ex Jerrysimon, as new, now built into 26" wheel £100
350W MAC , 10T (250rpm) from Cell Man. Well used but going well, built into 700c wheel, rim is worn out (split) - offers
Bafang BPM code 12 Rear Motor (Sensorless only) This is a geared rated 350-750w rated rear motor. I bought this from here as a very secondhand motor and used it to fill a gap. I recently tried to resurrect it without success. Built into 700c rim. Free to good home
Controllers;
e-Crazyman sensorless, brushless 36v controller. Has pedelec sensor. Well used but going well. £15
ditto for sensored motor. Well used but going well. £15
Tongxin sensorless, brushless 36v controller. From a 2009 batch. I never got this one to work. Free to good home
Desheng 36V 250W, I thinbk I used this during my brief use of jerrysimon's Tongxin above, less well used £20
Other;
Torque arm, nicely made 12cm total length £5
Half Twist Throttle with LED Voltage Level Display. New from BMS £5
I joined pedelecs five and a half years ago, in which time I've been through three frames, nine motors and nearly 20,000 miles. Time has come to clear out the surplus gear I've acquired along the way. I need rid of this stuff, some will end up in the bin, but I'd rather offer it here first if anyone, like me, enjoys to play around.
Everything is in Birmingham, can be collected from north or south of the city or posted at cost.
Motors;
Controllers;
Other;
