Help! Using a Carerra Vulcan E-Spec 36 voltDC Battery with a 36 volt-500 watt Bafang Mid-Drive Kit
Pemby66
Oct 14, 2019
Hi guys, i am new here.
I would dearly love to know if i can use said battery with a Bafang Mid-Drive Motor without any mishaps, or do i need to purchase a new battery?
Thanks for your time.
peter.c
1,612
493
thurrock essex
The battery is lower than ideal ah rate, the bms in the battery will not cope well with a 25amp load it will be short range even if it does cope
Better buy a battery with good branded cells about 17ah or above
Reactions: Pemby66
Pemby66
Oct 14, 2019
How about a lower wattage motor?
peter.c
1,612
493
thurrock essex
The spec of the battery supplied is poor even a 250watt bafang wants 15 amps
a tsdz 2 250watt only wants about 13 amps but the range will be limited budget on a new battery
Pemby66
Oct 14, 2019
Ok thanks, it looks like i will be selling some e-bike spares then!
Thanks for your help.
peter.c
1,612
493
thurrock essex
As spares are hard to get and a halfords spare battery is a small fortune you cold do well ;)
My pic shows a 250watt tsdz2 and a 13.5ah battery does 25-30 miles size limited by the frame triangle
Pemby66
Oct 14, 2019
Well, there is a wheel with a rear hub motor, battery with harness to attatch to bike and battery charger, crank and crank arms, bottom bracket. Only reason i am doing a mid drive conversion is because of a broken torque sensor (e21 error) and the bike's electrical system let me down way too many times, so i would rather convert to mid drive because there was too much pressure on the rear wheel(lots of broken spokes) so a mid drive is the only way forward for me.
Reactions: Audio2
