Used Samsung ICR18650 2.2aH Lithium ion cells
El Champiero
119
30
Bristol
I have 40 x Genuine Samsung high discharge ICR18560 22P cells for sale. These have been removed from a Bosch e bike battery which had about 18 months regular use. I am upgrading the cells myself for higher capacity 2.9aH cells.
Note that these cells have about 80% of their capacity left in them.
All the cells measure 4.2V after being charged using an XTAR charger. These cells have a lot of life left in them as the Bosch BMS limited the charge voltage to 4.15 volts and the discharge limit was activated at 3.6V. This feature on the BMS helps the cells to last a long time.
These cells can handle a 10A discharge current making them ideal for high current drain applications. Electronic cigarettes and torches would be perfect uses for them.
Please note that these are unprotected cells - you should use a BMS with them in a circuit or if you don't use a BMS, make you look after them well as they will be ruined if you discharge them to lower than 2.75V. Also, only use a good quality branded charger to charge them. Do NOT use cheapo chargers - they are likely to ruin these batteries.
I am selling them in units of 10 cells. Due to the fact that lithium ion cells are classed as Dangerous Goods they CANNOT be posted using the Royal Mail. Other private couriers charge a fortune for shipping these things (I was quoted at least £200 by DHL for example!). Therefore the only option available in this case is local pick up.
I can either sell them for £15 for per batch of 10 cells or £50 for the entire 40 cells.
If you are interested, please PM me and Ill sort out a time for you to come and collect in person. I am based in Bristol.
You can see my 100% feedback score on eBay by searching for "Lucasimas" in the search box:
eBay Search: Advanced Search
simon de meza
Apr 12, 2014
