Rented From: Philippe Roux ski shop, Verbier, Switzerland
Rental Price: about £25 a day
Time Rented: the day
Local Terrain: Mountainous
I'm posting here rather than in owner reviews, as I don't think a few hours' rental usage is a fair test.
Strengths:
Well built, to a price
Fairly lightweight
Stable and manoeuvrable in the rough stuff
Very fast freewheeling (up to 40 mph) and stable at speed
Assistance from the hub motor works well on lesser inclines
Precise derailleur gears, but only 6 of them
Good V-brakes, but very noisy in continuous use
Stylish and modern-looking (especially in black)
Very easy to use
Weaknesses:
Not so good on steeper inclines and no good at all on very steep ones
25km/h assistance limit seems slow and the 6th gear feels too low on the flat
Hub motor is fairly noisy when it is assisting
No handlebar-mounted switch to turn off the motor (unless you are a contortionist, you have to dismount)
MTB style of bike forces you forward into a gorilla-like posture – not to everyone’s taste
Gorilla posture throws weight forward on to handlebars and front shocks are not up to the job of absorbing the jarring over larger lumps and bumps (off road)
Summary:
Rented the bike for the day and took it up the cablecars to Col des Gentianes, about 2,900m high. Ducked under the tape marked “route barrée” and took it down a hair-raising rocky track, past rock slides, over the remains of late season snow avalanches and through shallow streams. Apart from the jarring at the front, I was much more impressed with how it coped than I expected to be. Then freewheeled on smoother dirt tracks and roads all the way back to Verbier at 1,500m. It went like the wind (and faster than some MTB’s), but then you don’t need an e-bike to do that.
I thought that I had better try its climbing ability, so chose some steep and very steep streets to try it out on. Whereas the Flyer C9 that I tested last week would have gone up anything, the UM36 (and I) balked at the steeper slopes. I was probably putting in about 200W of effort for a short period but it wasn’t enough and I had to get off.
In conclusion, this would be a good value bike on the flat and on milder slopes but if you need to go up mountains, get a bike with crank assistance and more gears.
Overall Rating (out of 10) : 8
Strengths:
Fairly lightweight
Very easy to use
Weaknesses:
Summary:
