Urban Myth? 36 volt batteries feeding 24 volt hub motor.
Mark Drake
20
I am not an expert on electrics so I hope that this is not a silly question,
I have an 24 volt ECO Stepper electric assist folding bike.
I have seen a few comments about people intending to substitute their a 24 volt battery with a 36 volt battery,
Has anybody actually done this?
Surely this will burn the 24 volt hub motor and other components out won't it?
Yes. I've done it on a couple of 24v bikes. It won't do any harm to the motor, but there's a very small risk to the controller. Controllers are cheap, so in the unlikely event yours does blow, you can use the opportunity to upgrade it to a much better one.
Mark Drake
20
I am pleasantly surprised.
What advantage does the 36 volts give you, faster speed, more torque or longer distance?
30,606
Faster speed, in theory 50% faster but maybe slightly less in practical circumstances. You probably won't be able to pedal fast enough to keep up with it.
Alan Quay
2,351
1,076
Devon
My 24v running at 36v (SWX) tops out about 21 mph. Very little torque at that speed though, so you can really only get that on a long flat stretch.
KirstinS
3,224
899
Brighton
I'd agree with that
But if you have a good 24v battery you can test 36v relatively cheaply by going down the booster battery route and adding a 3s (11.1v) battery made if 18650 cells. I get mine for free from laptop repair shops or drill packs
That way you only risk your controller
