i guess from that that a controller that could modify voltage and amps would be able to provide a setup with a single speed hub gear with lots of grunt low down (say 36V and 22A) and high speed (say 48V) - is this too simplistic, and why hasnt it been done then?Power is the product of speed and torque. Torque feels like power because it's the force that accelerates the bike. On a hub-motored bike like yours, the torque is more or less directly proportional to the amps from the battery. The motor can only spin to a certain speed, which depends on the battery voltage. Your motor is about 20 mph at 36v, so it'll do 26 mph at 48v. When you increase the battery voltage, you also get a proportional increase in torque, but a lower efficiency at low speed, which could be a problem if you had hills to slow you down.
You should therefore adjust the speed of your bike to the speed that you want to ride by choosing the right voltage, and then adjust the current to what you need for your weight and the steepness of hills.
There's no exact answer to what you want. Everything is a compromise, but if you're happy with 20 mph, you only need to increase the amps from the battery to 22A, which is about the maximum that your motor can deal with. If you want more speed, you need to get a higher voltage battery. 12S lipos will get you 20% more speed and torque, and a 48v battery will get you 30% more.
A realy good question.i guess from that that a controller that could modify voltage and amps would be able to provide a setup with a single speed hub gear with lots of grunt low down (say 36V and 22A) and high speed (say 48V) - is this too simplistic, and why hasnt it been done then?
It's been done a different way by Xiongda. They use the software in the controller to reverse the direction of the motor. Their motor has a double clutch. When it rotates one way, the internal gears give low speed and high torque, ant the other way it gives higher speed with lower torque - obviously both in the forward direction. It's a very clever idea that's robust and effective. It's what I have in my bike now.i guess from that that a controller that could modify voltage and amps would be able to provide a setup with a single speed hub gear with lots of grunt low down (say 36V and 22A) and high speed (say 48V) - is this too simplistic, and why hasnt it been done then?
