Uk Ebike manufacturers
Nivag
I heard recently Raleigh has moved production to europe and getting parts might now be a issue , got me thinking .
So what Ebikes are made in the UK, how many are there?
thanks
4,219
thanks
It depends what you mean by made. Brompton was the last British manufacurer that made the frames and cycle parts. There are still some specialist bike makers that make bikes based on traditional designs, but I don't think any of them do electric versions. Some brands do some basic assembly and checking in the UK, like Cyclotricity, Mirider, Woosh and Wisper(?).
If you want a secure parts supply, you'd be better off sticking with a standard Chinese bike. You can still get parts for such bikes that were made 14 years ago. The closest to that is Bosch, though it's becoming much harder to get parts for the early ones now.
AGS
620
195
Cooler King is a UK company, but their bikes are themed on motorcycles and made in China. They appeal to me but I don’t think many on here share my enthusiasm for them.
3,410
I'm really digging their model with sidecar. 50kg sidecar load weight is too low for a normal sized adult, so is 750W for two normal sized adults. I guess the sidecar cockpit could be unbolted and replaced with a larger volume cage for cargo.
The sidecar is on the wrong side for our UK roads.
4,219
You cannot register a sidecar outfit that has the sidecar on the wrong side. They were banned in 1981.
G
Ghost1951
I rode a sidecar outfit for a couple of years when I was a student. It was a terrible machine with dangerous tendencies, like the sidecar rising up off the road if you turned left at anything but a pedestrian pace. It never braked in a straight line either and how much it veered depended on how heavy your passenger was. The whole idea of such a contraption is a horrific make do, born of a period when people had motorcycles, and a family and not much money, so they cobbled this dangerous contraption together.
Those things may look cool to some people, but if you'd ridden one, you might feel differently.
Reactions: thelarkbox
AGS
620
195
It’s for Americans. Our roads aren‘t suitable for side cars and our culture doesn’t appreciate them either.
3,410
Any faster than 8mph, my 15.5kg Homcom bicycle trailer is a bit hairy to tow when loaded with 75kg. I guess my bicycle with a sidecar carrying the same weight, would handle weirder.
This bicycle sidecar is for the correct side:
https://www.ebay.co.uk/itm/266942599197
There were cargo versions:
There must surely be new sidecars for bicycles somewhere? I could hog the road at 8mph.
G
Ghost1951
Around here it is quite common to see farm dogs riding on the back of quad bikes as the farmers drive from one field to another. They are incredibly adept at jumping up on the rear platform of the bike and they brace themselves as they go around bends, often going quite fast I never saw one come off. These are very intelligent sheep dogs though, and they cost thousands. The people who use them could not work without them.
This is not my photo - I just snaffled it as an example.
59324
4,219
I rode sidecar outfits for three years in 1971 to 1074. First an Ariel VB with a home made box on the sidecar chassis, then a Triumph 21 with a Steib SA sidecar. They're very weird at first because of the reversed steering. Everything is wrong about the dynamics of the off-centre mass, drag and momentum, which all work against you once in motion; however, you do get used to it, and it becomes manageable as long as you keep the speed down. Riding in the snow and ice is very safe compared with a solo bike. The one thing that's difficult to deal with is emergency situations, as you cannot steer to avoid things. Every turn needs to be planned in advance by the appropriate use of speed and acceleration. Braking while turning left is simply not possible. With all that in mind, I'd say that those sidecar outfits are not safe enough for modern roads and traffic unless you have a sidecar wheel with at least a brake, and motorised as well, ideally.
Reactions: Ghost1951 and flecc
Nivag
....you'd be better off sticking with a standard Chinese bike. You can still get parts for such bikes that were made 14 years ago. .....
What are the 'standard chinese bikes'? there seem to be so many.
AGS
620
195
There are many, so just pick one on eBay that you look the like of. Some of them are even UK compliant.
4,219
The ones that have a standard hub-motor, a Hailong type battery, a standard LED or LCD control panel, a standard pedal sensor (torque sensors not allowed) and no phone app associated with them. Basically, check that the battery and control panel are readily available on Aliexpress. Motors are all interchangeable, so you don't need to worry about them.
In summary, if it has a Hailong type battery, it's probably OK as long as they don't claim that the bike has any unique features, like tilt control, belt drive, auto-locking and stuff like that.
That £360 argos bike is the perfect example. Every electrical component can be swapped with other standard ones. The battery, controller and control panel can be easily upgraded to whatever you prefer. The bike itself has all standard bike parts that you find on any catalogue bike. They can all be upgraded or changed if you want. They're all proven to be robust and reliable. A bike like that should last for years until the battery gets tired. The chance of something going wrong is extremely low.
G
Ghost1951
I charged mine up when I first got it, rode 9 miles and then charged it up again and rode it seven miles. I just checked the voltage on the battery output pins when I was trying to free off the stuck power switch. The voltage was 40.3V. After seven miles of riding, that suggests a fairly meagre sipping of battery power and a decent range as long as you are not racing and letting the motor do all the work. I am hoping the battery on this thing will be good, and it does look like it. That battery is at around 83% after 7 miles! I'm surprised.
I was almost all the time in the middle of the three PAS levels. Two years in a crate doesn't seem to have harmed the battery at all.
G
Ghost1951
You and I have had many similar experiences. That span of 'outfit riding is similar to mine, only I dumped mine in 1974 for a 1960 Morris Thousand - mine was an 850cc engine.
What you say about the snow is certainly true, and I would add bad fog to your 'better than solo'. I used to ride mine up and down between Newcastle and London when I was a student and one time, being the world's worst mechanic, I had 'adjusted' the chain in Newcastle at my mum's house, and set off for London, only I had set the wheel out of line and as I climbed a hill on the A1 near Tadcaster the engine (650 BSA A10) roared and dropped the chain on the road. I thought I was tooled up for every eventuality, recovered the chain and got out my big old chain tool and spare link, but when I looked at the chain, it was horribly shredded all through its length. With another 190 miles to go and a big load in the side car (all my gear and my girlfriend' stuff) I got it towed into a local garage for storage, and took a massive amount of gear on buses and the train and eventually ended up in Twickenham. Next day - a mate of mine with a BSA 250 - I think it was a B25, high compression thing and rather flashy, came with me to Blades the motor bike parts shop in Twickenham and got a new A10 Gold Flash chain (or so we thought). We set off up the A1 for Tadcster. It was the dead of winter. I am thinking it was just after the Christmas holiday, and we were pretty cold.
We offered up the chain the complete Knacker at Blades's had sold us and it was the wrong size. Turned out it was for a BSA A65, so we rode to Leeds and got the right chain, went back to Tadcaster, and fitted it.
By now it was pretty late and nearly dark and it was also foggy. Off we went back down the A! at about 45 miles an hour and the fog got worse and worse and started freezing up in my beard and hair poking out under the helmet. Pitch dark and a white out of fog. Pretty soon, Brian my mate was riding pretty much blind at 30 miles an hour and he could not keep the bike steady because he was losing his visual reference as to where vertical was. For me it was easy . The thing just sat there on three wheels and all I had to do was not run off the road. So I overtook him and led the way all the way down. he said that once he could see my two tail lights he knew how to steer straight. At one point, my A10 engini started misfiring badly, so I pulled off into a lay by and took a look - feeling really, rather than looking, because I had no torch and only Brian's headlight to help me. The magneto cam had come loose.It was a sort of weird oval ring with the points flying around in the middle and the cam ring had lost one of its little machine screws, the other was loose and and the cam ring was floating about, hence the terrible ignition timing problem. I hunted around in the bottom of the boot compartment on the side car and could not find one anything like it, but there were some tiny wood screws, so I stuffed a bit of match stick in the hole that I had picked up in the lay by and put the wood screw in, and that got us home, albeit with a few pops and bangs from the mis-timed engine.
So that's how a sidecar can help you in fog. It can keep you vertical when you can't see anything.
esuark
330
220
kent
Do people still have "adventures!" like that anymore in this "modern" age?
