U.K. Charger for Batavus Protanium battery charger
we have a Batavus with Protanium 29v 10a battery and 29v2a Protanium charger.
I'd like to use a uk sourced wall charger (and ideally 3 pin plug) that feed into the Protanium charger but still out of habit use the Dutch supplied 2 pin wall charger cord. Naturally I'm afraid of damaging the battery with an incorrect charger but would like a more stratforward way of charging than converting 220/240 to 110 and then into the Protanium charger. Might be a Maplin job unless readers can offer wisdom or recommended products
Thanks for reading!
I thought the voltage in Holland, and the rest of Europe, was the same as in UK.
Are you sure it's 110v?
Here's a charger on BE ebay and in indicates an input voltage of 100 - 240 V.
Is your charger similarly marked?
If so, just cut the plug off and fit a UK plug in it's place.
