Following on from other threads I have now recieved the kit and started fitting it to my Trek Hybrid.
First is that for some reason the motor connection does not just plug into the battery. I assume that the wire has to be joined to the two white plugs which are attached to the motor. Is there a simple way of doing this, ideally without soldering?
The other issue is that the two bolts holding the battery to the frame are both in the bottom third of the battery. The battery is a 48v 17.5Ah so quite large. It does not feel safe only being held on so low down with two thirds of the battery unsupported. Are there any straps etc that might help. There is no way to thread cable ties through the base plate?
Steve
Steve
