I've never really understood what the benefits of tubeless tyres are. But tbh i dont usually offroad, so few instances of tyres squirming under pressures of rocks,roots and drops.
What I have noticed though on bike forums is the incredible amount of faff* in getting these things seated. New special pumps requiring reservoirs to suddenly blast a big shot of air in, the need to completely seal the inside of the rim with tapes, the need for special valves, and far from preventing punctures, punctures still are a problem. So we have more things to buy, to core out holes and fill them with a plug, or internal patches or even...get this...sewing them up
because tyre casings are now so supple, they could be viewed as being weak or flimsy.
They need a sealant put in which apparently clogs air valves, or fails to actually prevent leaks and even after all that, there is a finite life on the sealant and you need to periodically clean the inside of the tyre, which is now covered with semi dried sticky stuff that is by many accounts a real faff* to clean.
Prior, it was an inner, repaired quite easily using patches that cost a quid for 5, to internal tapes, valves,sealant,hole coring tool and plugs and even a new style pump, all of which adds up to a pretty penny.
And most riders, despite all this, seem to carry an old fashioned innertube all the same. Because we still get holes, and it seems the new tubeless stuff fails to repair so you then need to fit an innertube to keep going.
OK I understand there's also a weight saving. But it can only be a few hundred grams, so is it really worth it on anything other than an All Mountain,Enduro or Downhill bike set up and probably only then if you ride hard or aggressively. Certainly I see zero benefits for commuting tyres or even general trail or XC offroading.
* I think you know the word I really mean here
