The 52t front chain ring trial proved to be a compromise to far , had to give up with the 7 speed set up after a 28-13 and a 28-11 as the hill climbing ability suffered but great on the flat
Plan b replace with a 10 speed gear set but rear wheel is a screw on freewheel and just hard to find or a rip off ebike special at £70.00 [just for the freewheel ]
Managed to locate in china just had to wait for the slow boat , but arrived today and all fitted ok only required the simple fix of 2 spacer washers so the freewheel cleared the frame
With the standard front chainwheel back on and the rear 36-11 the fun factor is back
PARTS USED
Screw on freewheel 36-11 - 10 speed derailleur - 10 speed thumbshifter -10 speed chain and 2 washers
PARTS USED
