I think that I have decided to convert my 24 gear hybrid (cross) Giant bike rather than buy a complete electric bike. Partly (well largely) economy, partly because the bike and I have got used to each other and I can't see a new bike in my price range being built with the same quality of components. The modification will be the 8fun kit.
Some questions which I would greatly appreciate help with please:
I note that some forum users describe putting the pedelec sensor on the left had side retaining full chainwheel changer functionality. However I read in much of the literature that only a limited selection is gears is needed, mainly the high gears. Would it be better to remove the inner and middle chainring and mech then fit the pedelec sensor on the RHS?
How important is the brake cut off? If I keep the chainwheel thumb control I cannot fit the special cut off brake mechanism. Similarly I can't fit the motor only throttle lever. If I do remover the chainrings and associated brake/shifter assembly I can fit the brake lever and the throttle lever (on the LHS) though the bike will have odd brake levers which will look strange.
Also I am a bit concerned that the front hub motor will impose excessive load on the front suspension - should I change to rigid forks?
Any advice welcome, thank you.
