Translucent glue required.
Fordulike
3,802
1,538
Can anyone recommend a completely translucent but strong glue, to stick plastic to plastic.
I'm reluctant to use super glue, as it tends to dry white sometimes. Plus it's pretty s**t at sticking anyway. Apart from fingers :rolleyes:
mike killay
3,012
1,629
Stixall clear is very good, but be aware that nothing will stick to polypropylene.
I have been trying to seal a leak in my wheelie bin without success.
Reactions: Fordulike
30,578
Welding with a hot soldering iron often works to seal such a problem. A hot enough hot air gun can also work.
Reactions: mw1 and Fordulike
Mar 9, 2016
833
402
Depends on the plastic..some have to be "ionised". Ie) just pass a flame over surface to be glued.
On boards I often have to reattach/ renew plastic ( Acrylic) footstrap inserts into foam ( EPS) and epoxy/ carbon laminate.
Without a doubt best I,ve found is uv resistant, clear ,low viscosity epoxy resin ( its on ebay) Only problem is 9hr set time.. You must identify the plastic.( some polyethylene) are almost impossible to bond and must be welded, but you can only do that to same material.
I,d try one mentioned.(without a medium (ie carbon or gladd strand) it sets quite flexible. ( Its the working bit of araldite, but that has fillers) If you do use pure epoxy resin mix it exactly and thoroughly.
