Total newbie looking to buy an eBike, want some advice on a model!
Karliah
44
7
Hi all,
I am looking to buy an eBike, I have an offer of a Shengmilo MX05 for £750 Brand new in box, I'm not sure if I should take it or not or look elsewhere, my budget is definitely around that price point.
Some additional information:
I have a normal bike already that I love, so I am totally open to getting a conversion kit although it is more hassle, I do have the capacity to build my own lithium ion 18650 battery with the help of a qualified electrician, if it will save me a significant sum of money.
- The shengmilo has a really long range, My health is quite bad so I would want the comfort of knowing I can get back without pedaling much of that makes sense.
One person has told me that the MX05 is not road legal, looking for some advice on this as it says it conforms to UK law, can be limited to 15mph etc, looking for some advice on that.
If you need any more info please let me know, as I said I know nothing about this sector, so all advice is welcome
Karliah
44
7
Yep, i'm very pleased with the two kits I bought from Yosepower UK (not Aliexpress and both delivered in 3 days). I bought one kit without a battery and share one on the basis that I can only ride one bike at once! :D
I effectively got two bikes kitted out for the price I would pay for one elsewhere. However, @Woosh makes some valid points. The over-long cables are a bit of a pain but I was able to overcome this with some "creative" routing without cutting them. It does help to hide them if your bike is black! The long motor cable is perhaps the worst part if you get a puncture. If you are of a practical nature and don't mind taking time over it a decent job is possible.
Product support is very good but it is email from China so not as good as a UK supplier.
It's too early to say how the good the battery is (bought in March and getting to nearly 600 miles between the two kits), but I'm not expecting too much bearing in mind the price.
Do you mind linking me your kit so I can take a look? I'm on the site now and something like this
https://www.yosepower.co.uk/products/e-bike-conversion-kit-36v250w-front-motor-36v15-6ah-hl-plus-batteryhttps://www.yosepower.co.uk/products/e-bike-conversion-kit-36v250w-front-motor-36v15-6ah-hl-plus-battery
looks great.
Karliah
44
7
ebikebatteries.co.uk do also accept cheques.
But I fully understand if a lot of not long on the planet people have no idea what a 'cheque' is.
I asked for one and the bank wouldn't send me one as they are "Phasing them out for ages 20-35" Couldn't believe what I was hearing. It was almost like they were saying my age group doesn't use cheques enough so they wouldn't send me one!
30,768
Your link is doubled and only gets error 404. Here's the corrected link:
Cadence
298
219
You linked to a Yose front hub kit. I have no experience of those.
I bought a 28" wheel 250w. rear hub kit for cassette with battery:-
36V250W 27.5"/28" Rear E-Bike Conversion Kit for Cassette with 36V13Ah – YOSE POWER UK
I've since bought and fitted a more powerful 18amp Yose controller which also allows the throttle to be set to "full" (it's only "walk assist"with the 250w. kit controller):-
Slider for Hailong-I Battery / or with Integrated Controller – YOSE POWER UK
The other kit is a 26" wheel 350w rear hub kit for freewheel without battery:-
36V350W26"/27.5"/28" Rear E-Bike Conversion Kit for Freewheel – YOSE POWER UK
Of the two, the 350w. kit is more powerful and it accelerates quicker, but not by a huge amount more than the 250w kit fitted with the 18 amp controller. It also has a settable top speed up to 20mph (250w is fixed at 15.5 mph max.).
The 250w. seems to be better at climbing hills and Yose quote a higher torque figure (58nm. as opposed to 48nm).
Both hubs are clearly marked so if you want the peace of mind that comes with being fully street-legal, the 250w. kit is the one to go for.
Peter.Bridge
1,565
718
If you wanted a new electric bike, this seems reasonable (they are out of stock of the £799 version at the minute, maybe enquire about it) 48v should be quite powerful,768 wh battery is a good size
Difficult to derestrict though (think you would need a new display and / or controller) but I don't think you were bothered about that ?
Karliah
44
7
That's brilliant, thanks for that. I will take a look at them, I do have a separate controller that I stumbled across and I have no Idea why I have it or if it's suitable, will post a picture of it if I can and a picture of my bike
Will just post what's in the box
Just had a look at my bike and it's laughably unaccessible right now, but I've found what is the same one online, it says Apollo Transfer on it and looks like this.
Seems like a fairly cheap bike but it's a nice ride, although I have nothing more expensive to compare it to @Az.
Appears to be this
Although in a different colour way to the image I posted above
Hope that helps?
Cadence
298
219
That controller has a higher wattage than the one that comes with the Yosepower 250w. kits, but the Yose controllers are Lishui brand and come with waterproof Julet connectors. You would have to identify all the wires and cut/solder them. Even then, it may not work with the Lishui C500 display (no brand on your controller's label?). Also, if you buy the Yose kits with the downtube battery they have the controller built into the battery holder. It's best to stick to Yose components if you buy their kits as they do come with a warranty.
That Apollo Transfer is a rather basic hybrid but it would be suitable for conversion. If yours has 3x6 gears it will be a freewheel fitting (not cassette) if you go for a rear hub kit.
8,722
The 22a controller in the pic is a KT so the Lishui 500 display will not work, you need a KT lcd display the it will work. The KT is better then the Lishui and are so much easier to get hold of, Lishui are 99% OEM only.
With KT controller there is no need to cut any wires simply buy KT periferals that have the SM connectors and they are plug and play.
Karliah
44
7
Right, understood on all of that. Happy that I can covert it, it does the job and I can always upgrade to something else later down the line
Would you recommend a front or rear wheel?
People on this thread have explained the differences but it doesn't get me closer to a decision as it seems they both have pros and cons?
For basic paths, pavements and the odd incline, I'm not sure what would better suit me honestly.
Karliah
44
7
Okay, so it seems it's worth it to use that controller and get a different display if I go for that conversion kit?
I think the Lishui is 7A with a max of 15, is there a point of diminishing returns with the same motor? Unsure where that point is?
6,689
if you send to many amps to the motor winding and it cant cope with it that turns in to heat if you keep going the motor core will over heat and be de magnetised and kill it or also burn up the motor windings.
Reactions: Karliah
Cadence
298
219
I swapped the 7Ah/15Ah integrated controller in the Yose 250w. kit for the 9Ah/18Ah integrated controller that comes with their 350w. kits (available separately). This did give a noticeable improvement in torque and acceleration, but I did it mainly because the 250w kit throttle is "walk assist" only. Using the 18Ah controller I was able to set the throttle to "full" with the C500 display that came with the 250w. kit.
You may or may not think this is worthwhile (and it is strictly illegal) but I find the throttle useful when setting off at busy junctions, traffic lights etc. I found the performance of the 250w kit with the standard 15Ah controller perfectly adequate for my needs, but it really depends on what you want from your bike.
I don't jump over rocks or logs, or pretend that I'm in the Tour de France. I'm also not interested in messing about with loads of settings. I just like riding my bike for fun with a helpful little "push" when I need it. :D
Reactions: Peter.Bridge
Az.
2,170
983
Plymouth
Looks like there is a good chance your bike can accept any kind of conversion. I suggest front or rear hub motor. No point to install mid drive on your Apollo.
I am glad to see you have abandoned idea of buying Chinese moped. Many of us have many decades of cycling experience and we know when we see a good deal. For example this bike is at good price:
Combined with conversion kit it would be above your budget, bit it is a proper MTB. Something to think of and/or keep an eye on as you can get it £100 cheaper from time to time.
30,768
Front motor would be fine for that basic usage, keeps it simple and your bike has the desired steel forks for a front motor.
Karliah
44
7
Yes, you will be pleased to know I have realised that there are better options than chinese moped, I know I have the flexibility of getting exactly what I need for probably half the price that the Shengmilo would have cost me.
Can I just query what @Cadence said, why would replacing the Integrated controller on the 250W for something with a higher amp output make it illegal? Is it just because it would push it above 15.5 MPH?
Also can i ask what is "Walk Assist Only" that would come with the 250W Kit? I'm perfectly happy with a kit that can get me to 15.5MPH (Without pedaling) and keep me there for an extended period of time, that's what I'm looking for currently after all the brilliant advice I've received, I can start off with that and in the future if I need something with a bit more go in it, I can upgrade.
30,768
It's throttle that only operates up to 4mph maximum, for use when walking the bike up any very steep hills you cannot climb, or to help you away from a standstill, aka Start Assist.
30,768
Cadence didn't mean the higher amp rating made it illegal. He meant that the different controller allowed an independent fully operational throttle setting for all speeds up to 15.5 mph, which is illegal. The law says power only when pedalling, in other words motor assistance, not motorcycling.
Karliah
44
7
Walk assist works for up to 6mph if I remember well. It is used when you want to walk, but you are not really keen on pushing your bike (up hill for example)
Right.... That seems pretty useless then for what I want, unless I am missing something, it will only propel me up to 6mph?
Right, now I'm really confused, is electrical assistance without pedaling at all illegal?
