Yeah thats Ideal 2-24 covers about everything bar the cranks and cassette lockring.
As many components are alloy, overtightening can cause loads of issues, and constant overtightening will wear the threads possibly leading to a failure there, or components with an alloy clamp can snap if too tight, or move in use if too loose
Places you need to be extra careful, are things like stems/bars or brake mounts. Over tighten an alloy stem on an alloy bar, it could lead to the bar failing. Carbon components are even more torque critical
I'm pretty rigid about following recommended torques, but mainly cos ive rather pricey components, so I wouldnt want to break something or worse have it loosen off in use.
Anyone looking to leave cackhandedness behind I've heard Norbar is a good one to get.
#TIP- Never leave the wrench torque set if not in use, always back it right off as the internal spring can be weakened, which will effect the setting by giving you a false reading.
I use the effetto mariposa giustaforza ii deluxe 2-16nm, with a small fixed head so it fits into tight places. It's not cheap, but very reliable, and I've had mine for at least 10 years.
