I knew these were going to be a bit of a b'stard ... been playing about to see what can be done. Arms are M12 from BMS. The bike is upside down with the motor axle slotted in the dropouts. Axles aren;t the longest for adding these in
1st appraisal - drive side.
A full swing to frame fixing point with a clamp would look like this. This is within the dropout section before the weld to the main frame and so would be trying to fix around some relatively narrow bits of metal. Would that be safe ?
Not sure about whether optimal plane in any way but advantage of this approach is that I could grind off some of the rack housing (shown held in place with an alum key) to just fit the rack in to the spare hole. It's very tight though.
2nd appraisal - non-drive side.
This is a bit of a b***** owing to the frame design in the dropout area and the dropouts being completely vertical. Great for everything else, not so great for options with this torque arm. Nonetheless .....
aligns like so ... I have removed the rack - mount hole is the spare one as here :
It will pivot to the rack fixing hole (drilling out required) :
... but this means rack goes which isn't really an option on this build.
It will also pivot to the lowest hole (uppermost when bike is upright) - which means attaching through the same hole as is being used for brake mounting (mocked up here) :
... but this again interferes with the rack mount hole and likely would lead to some extensive grinding away of the rack fitting. Perhaps too much for it to still be strong enough. It's very borderline.
Hope I've oriented the torque arm right ... are any of these options not recommended technically ? Whichever way I go with this it seems quite a bit is going to be needed to get these torque arms to fit without losing option for a rack. The least work would seem to be drive-side fit as in 2nd photo above which only involves grinding away a very small bit of rack mount block. But I am a bit worried about my frame and whether it's OK to fix here with a clamp.
