Tongsheng TSDZ2 no pedal assist.
Les186
11
9
Tongsheng TSDZ2 kit with VLCD6 display fitted to Orbit tandem. Battery is Hailong 36V 13A. Unfortunately there is no pedal assist! Connected the throttle and the motor sprung into life, however still no pedal assist. So is it the torque sensor or the controller or can anyone suggest something else? Could it be the wrong firmware, e.g. set up for a 48V battery? I will contact the Chinese supplier, the kit came via Aliexpress.
Reactions: Bikes4two
Bikes4two
997
428
Havant
Hi Les,
  • There's a few possible lines of investigation mention in the post HERE
  • The Hailong battery you are using - you didn't mention if it was a new one or used from somewhere else?
  • Either way, do you have a way of monitoring the voltage at the time you engage 'walk assist' and ask for normal 'assist'?
  • I say this, as if there was a battery problem of some sort, you'd see the monitored voltage drop right off. T
  • If the battery is a 'doner' from else where and it was allowed to discharge too much, then the battery might not recover enough to power the motor.
  • I have a little voltage monitor that plugs into the charging port - I've just plugged it in and the battery voltage drops by 0.1v when 'walk assist' comes on.
  • Another source of information is the endless-sphere.com forum. If you search as I have just done for 'TSDZ2 Torque Sensor', there's a lot of 'hits' to follow up on.
  • See this endless sphere posting as an example of what worked for someone with a problem similar to yours - link
  • And there is a github page for wider reading HERE
  • Do please keep us all informed on progress with resolving the problem, especially the response of the supplier.
  • Many TSDZ2 buyers like to go for a UK supplier for the comfort of 'after sales' support - laudible of course but it comes at a price, a price worth paying if you're not one to delve into the mechanics of these things when they misbehave.
Bikes4two
997
428
Havant
There is a question around whether a faulty speed sensor will give problems (as in no assist) - opinions vary - so I've just been out on my TSDZ2 (VLCD6, 36V, 250W running OSF) to see what happens if I remove the wheel magnet:
  • The system boots up and I can pedal off and assistance kicks in
  • The display DOES NOT show any speed (as you'd expect)
  • After pedalling a few 10's of metres, the assist stopped and error E08 showed on the display.
  • Error E08 is Faulty speed sensor or magnet too far away.
I powered down from the display and replaced the magnet:
  • The system boots up and on pedalling, the speed is shown but still no assist
  • Powered down again FROM THE BATTERY SWITCH and this time I left power off for about a minute
  • On powering back up, all was good ie speed shown on the display and assist working
Whether this is the same for those run stock firmware, I couldn't say.
So Les, when you pedal off on the tandem, are you getting a speed on the VLCD6?
Les186
11
9
Thanks for the posts. The battery is new. I stuck my multimeter probes in the charging socket and got 41V. When I engaged "walk assist" the voltage fell to 39V then rose to about 40.5V. I tried pedalling and the voltage remained at 41V so no assist as expected. Thanks also for the links, I'll have a look.
Les186
11
9
I forgot to mention that the display does register speed and distance. When I first tried a wee pedal the magnet was in the wrong position and no speed was registered but I didn't see any error codes.
AndyBike
1,326
562
I'd this the other day. Started off and felt zero assistance, and thought oh God.
Then I noticed it was switched off :rolleyes: silly me.
Les186
11
9
I got a reply from the supplier (BOLLFIT Ebike Store) requesting a video to show my problem? As somebody said perhaps a video of me at the top of a hill all red in the face and sweating because I don't have pedal assist.
Bikes4two
997
428
Havant
  • That should be a laugh then Les - getting the video that is!
  • I should think that if you raise the back wheel off the ground (suspended from a garage roof beam on a piece of rope or similar?) take 3 video clips of
    1 - the VLCD6 display showing the screen with battery bars and being able to select different assist levels and then someone to turn the wheel with the speed sensor on it to show that speed is being 'seen' by the system
    2 - a shot of the chainwheel going around whilst someone activates 'walk assist' and audio clear enough that the motor can be heard running
    3 - another shot of the chainwheel and cranks whilst turning the pedals but with audio pickup sufficient to demonstrate that the motor IS NOT running. Even if audio is poor, the video will show that when you stop pedalling then the chainwheel also stops immediately. If the motor where running, the chainwheel normally runs on for a further second or so.
  • be sure to mention that you don't have ebrakes fitted and what you'd tried with the throttle.
  • sounds simple - NOT! - anyway, good luck with it all. Hopefully the seller won't want you to return the motor to China at your cost.
  • I once had a problem with an Android car stereo touch screen - I had to video that - they then sent me a replacement touch screen which I had to replace myself - just as well my professional background was in electronics!
  • How are you as TSDZ2 dismantling?
Les186
11
9
Thanks for the advice. I had a first stab at making a video showing most of your points but it was too large to send even after compressing the files. I have now sent two videos, one "assist" and the other "walk". I'm not sure about the quality of the videos - Steven Spielberg I am not!
vidtek
423
243
Bournemouth BH12
Use a free online cloud storage like dropbox or Mega and just send them a link.
Les186
11
9
Have now heard back from Bollfit Bike store. They reckon the fault is with the Torque Sensor and have offered to send me a replacement if I pay the postage. I have accepted (£10.44) so will wait until the slow boat from China arrives
smiley
. The Torque sensor looks like one of the more difficult components to replace. I think I will remove the motor from the tandem to make things a bit easier and hopefully avoid losing any of the three little springs I have read about.
Les186
11
9
Fitted the replacement torque sensor and alas still no pedal assist. Got back to my friends in China and they asked for another video and the serial number of the replacement torque sensor. Sent them a video of the pedal assist not working and the throttle driving the motor but asked if they really needed the serial number of the torque sensor as I didn't want to strip the motor again. They replied they really needed the serial number, so I started dismantling the motor. The first time I needed to fashion a puller to pull off the big gear but this time it pulled off no bother. With the big gear removed the torque sensor rotor is exposed which has a hand written number on it which I photographed and sent to China.
Does this mean that torque sensors must be matched with motors?
8,517
No.
Reactions: Les186
8,517
8,517
My bet is the controller has an issue.
Les186
11
9
Yes you could be right. We'll see what the boys(girls) in China think.
Les186
11
9
My Chinese friend asked me to send the video again as he didn't receive it. The video was taken with the tandem mounted on a work stand and me turning the pedals by hand. I got this reply.
"hi friend
Our technical department said that if there is a problem with the torque, it must be judged by someone riding on the bike. It may be that the effect of shaking it by hand may not be obvious."
I'm sure the hospital doctor will understand when I tell him I was trying to video myself riding a tandem:confused:.
Bikes4two
997
428
Havant
Hi @Les186 ,
When you are peddaling and the motor is running under power then:
1. you will hear the motor
2. when you stop pedalling, the chainring 'runs on' for a few chainlinks due to the power tapering off - you can see this phenominon in the UT clip here. Conversely if the motor IS NOT being powered, apart from not being able to hear anything, the chainring, on stopping peddaling, stops almost immediately.
I use this phenominon to check if my system has inadvertantly shot off whilst riding (which it has done several times whilst I investigate a BMS shut-off issue)
Thus if you can rig up a camera to record the chainring whilst cycling, then that should provide a convincing demonstartion of the issue.
Les186
11
9
Thanks for that b42. If I use the throttle then I can hear the motor. Nothing with turning the pedals only. I thought having the bike on a stand would be convincing but I will give it a go once I rebuild the motor.
Les186
11
9
Was browsing Ebay and came across this item:
2X(Electric Bicycle Torque Sensing for Tongsheng Tsdz2 Mid Drive Motor S7M3) 4894847309060 | eBay
Looks like just the stator of the torque sensor but the thing I noticed was that just two springs are supplied. The replacement torque sensor I received came with two springs. The old torque sensor was definitely mounted with three springs. Maybe a different mounting or just two spare springs supplied?
I did mount the replacement torque sensor with 3 springs ;)
