Hi Guys,
Don't know if you can help, but im still having problems with my battery.
On saturday i went for a ride and covered 16 miles mostly on assist level 2
with some on 3 no throttle used.
By the time i got home only two lights showing so not too bad, however
today after charging last nite, within 100 yards of setting off one battery indicator light
went out which its never done before until Ive covered around five miles or so.
So does anyone know when the battery was made from the info below please.
Also i tried to check the individual cells from what i thought was the BMS as coming out of the battery pack are eleven black wires terminating in a plastic connector.
I could not get any sensible voltage readings from this connector.
Battery info.
AE7288195PMHRE
AE 120421000226
This is whats on the label on the pack.
I did think i would be able to check the individual cell voltages via this connector
but putting the neg lead on the neg wire and the pos wire on each tiny wire on the
connector did not read any volts .
There is certainly some voltage sag under load, and i would like to see if one of the cells
is off.
At the moment im a little dissapointed with the battery performance.
If it turns out to be normal then would the acquisition of a Headway Battery from these
guys EclipsEbikes be more robust than what i have now.
Cheers all Frank..
Battery info.
AE7288195PMHRE
AE 120421000226
is off.
Cheers all Frank..
