C
Cyclezee
Hi Tom,
That is an excellent and ingenious solution to a potential problem.
Although no one has reported a problem so far with the Freewheels I have fitted or supplied, I am seriously considering supplying a bearing with future orders.
The problem would be the spacer which would have to fit axles with different ODs.
Did you consider plastic tubing or pipe as an alternative to steel?
I am wondering if using uPVC or ABS pipe which was a snug fit inside the bearing and packing the remaining gap with something like RTV silicone would work?
The Freewheel would still be removable and the silicone would act as a shock absorber.
