I do try to use my electric bike as much as possible, but there are occasions where cycling or public transport is inconvenient, so the car is used instead.
I'm a stickler for keeping an eye on fuel economy, and over the last year the MPGs have dropped dramatically.
Also, the engine lacks the punch it had before the poor fuel economy.
The car gets a yearly service of the usual DIY stuff, air filter and oil and oil filter change, so the reduced fuel economy must be attributed to something else.
I will never go to a stealers unless I really really have to. Motoring is expensive enough as it is
So after doing a bit of research, I came across a couple of things that might free up a few horses and stop me from handing over my wage packet straight to BP or Shell.
One thing that gets overlooked at service time is the fuel filter. It makes sense that as the efficiency of a combustion engine relies on the correct air and fuel delivery, then if any of these two things are strangled in the system, then it will affect the running of the engine.
The second bit of research I came across is the fuel injectors. Apparently they are a precision part of an engine, and due to the fine tolerances can become partially blocked, resulting in poor combustion.
So, I popped onto Euro Car Parts website, ordered a new fuel filter, some fuel injector cleaner and a new air filter for good measure.
Fitted the air and fuel filter and poured in the injector cleaner. Took less than 30 mins.
Then took the car out for a good blast on the local roads, using lots of the rev range as some motoring forums recommend. Think it's known as an Italian tuneup
Hey presto, after about 100 miles (not done all in one day, I must add lol), I'm seeing an extra 5 MPGs on the readout. Acceleration has improved in leaps and bounds and the engine just feels more eager to rev and pull.
Won't take long for the savings at the pump to offset the cost of the parts, and then my wallet will be much happier
Who knows if it was the fuel filter or injector cleaner that did the trick.
I think the lesson learned is that a bit of preventative maintenance, whether bike or car, can go a long way.
